E-Class (W211) 2003-2009
Manually adjusting driver seat for removal
Old Mar 26, 2018 | 10:56 AM
baumnutde's Avatar
2004 Mercedes E320
Dear Members, for some strange reason, I can't seem to get my driver's seat to more backwards, it can move forward, and the other controls, (up or down) work fine. I recently purchased a new seat module, however, I would like to know if I can manually move the seat backwards to remove the front screws to get the seat out to replace the module. Any assistant would be greatly appreciated.
Old Mar 26, 2018 | 03:04 PM
konigstiger's Avatar
'71 Pinto
Can you access front bolts (3) at all, see attachment to remove seat. If not, see if you can identify any problems with tracks, move seat forward & up check from rear.
File Type: pdf
Old Mar 30, 2018 | 01:30 PM
'71 Pinto
Turn easy-entry feature off inclusive of key dependency then try moving seat back in 1, 2, and 3 memory positions respectively. If this fails, have someone pull fault codes using MB DAS (diagnostics) before replacing parts - could be module, switch, may simply need to be normalized. If steadfast on DIY see attachment to remove cushion this should give you access to motors, rails, etc. in an attempt to manually wind seat backward for front bolt access to remove seat.
File Type: pdf
Old Mar 30, 2018 | 02:44 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
I agree. I'd find out what the culprit is before replacing a control module.
