E-Class (W211) 2003-2009
w211 Wagon Liftgate Strutts
Old Apr 24, 2018 | 05:12 AM
JordanA's Avatar
2004 E320 Wagon, Base
New here, looking for some advice on replacing the gas struts on the liftgate (manual opening/closing) of my 2004 e320 wagon. Are these still available? I found this: 2004 wagon struts, but I am not sure which I need since multiple ones say that they'll work. Also, are the struts the same side to side, or is there actually a difference between the driver and passenger side units?
Thanks in advance!
- Jordan
Old Apr 24, 2018 | 11:52 AM
konigstiger's Avatar
'71 Pinto
File Type: pdf
Old Apr 24, 2018 | 08:02 PM
JordanA's Avatar
Thanks for those part numbers and the instructions (I know HOW to do it, just need the parts!). I found the part numbers above in an older thread, but finding the actual parts is a different story. It seems that one side is readily available but the other is not, which is why I was curious if there was actually a difference between the two.
Edit: I was able to find the genuine parts online using the part numbers, but is there an off-the-shelf third party part that works as well?
