E-Class (W211) 2003-2009
Injectors replaced heavy knocking disappeared but still smoking hard.
Old Apr 26, 2018 | 08:13 PM
sheikhnav's Avatar
W211 220 07
Hi people,
Just like to say a quick hello to everyone first, although not new to the forum but this is my first post.
I have had injector 1 replaced and few thousand miles ago. She has done nearly 300k now . After doing a 200 mile journey over the weekend perfectly fine, the next morning she started up to heavy knocking noise and white thick smoke. I made the assumption one or more off the injectors had gone due too the severity of the knocking noise and smoke. If it did not knock so I would have gone down the road of a blown turbo. Injector 1 and 2 seemed like the likely culprits this time. I decided not the cheap route but get all the injectors checked by a diesel injector specialist whom confirmed injector 1 and 2 where gone and advised 3 and 4 should be done also as they weren't too great either. Injector 3 seemed an original Delphi one to me as the bolt was an original long bolt still.
So I have replaced all 4 injectors now with refurnished one, not cheaply. The knocking noise has disappeared now completely and the even seems to sound idling quieter than before but she is still suffering from thick white smoke. I have allowed it to run idle to see if it clears away with no avail.
But to the turbo, maybe ? After taking the car down it seemed like the smoke had reduced by about 40% and remained to smoke under acceleration. Doesn't seem to be a lack off power nor does the smoke really smell like oil smoke more diesel.
I've scan her and she only comes up with code P0670 and P2030. No other faults showing.
Any advice in what direction I should be heading or at least looking towards for now.
Much appreciated guys, thanks in advance
Old Apr 27, 2018 | 12:23 AM
bbbbbbb's Avatar
2013 benz c250
Originally Posted by sheikhnav
Hi people,
sounds like you're running too rich with the fuel, which means you may need to have you ECU flashed or even perhaps the High pressure Fuel Pump may need to be looked at.
Old Apr 27, 2018 | 08:29 AM
sheikhnav's Avatar
W211 220 07
After all the injector problems, could it be the engine oil being diluted with diesel and the oil level too high?
Old Apr 27, 2018 | 11:19 AM
PSDCampervan's Avatar
2005 E320 CDI (SOLD); 2008 ML320 CDI 4MATIC
It could be a missing or extra injector seal washer... My car was running a little rough, getting poor MPGs & smoking pretty consistently after stealership install of new injectors. Even at idle it was smoking out tailpipe which it had NEVER done before. I monitored 'smooth engine running' in CDI_3 control unit via DAS & determined #1 was overfueling consistently so pulled this one to find tech who had installed put 2 copper sealing washers in this bore instead of 1. I reseated injector w/ 1 new copper seal & stretch bolt. Smoke cleared up & no more overfueling in DAS. After seeing that shop fail, I decided to pull & replace seal & stretch bolt on the rest for peace of mind as I travel long distance in this vehicle so need it to be reliable. Found 0 sealing washer on #2 & evidence that black-death was creeping up bore after only a few miles. The rest were correctly installed but tech stripped #3 hold down bolt so put in a cheap springy helicoil there. Car runs & idles beautifully now & IC shows excellent MPGs again after I cleaned up dealership's sloppy rushed work.
Old Apr 29, 2018 | 09:46 AM
Maroc_Specops's Avatar
W211 E320 CDI Sportpackage With Carlsson CD32 Chip 2004
Hi people,
did u clean ur egr valve. 2 bolts and ur there. Also get of the black plastic cover and remove sooth and Debris.
