2006 E350 Torque Converter Drain
You may want to get two sets of screws; that way you can do the pan service again in another month, then you would gotten the majority of the old fluid out.
If you don't have the plug, I have seen video where the guy dropped the pan, fit a hose into filter hole, put the hose into 1-gallon container with ATF and started the engine to flush the fluid. The return was splashing down open transmission, so a bit messy job, but does the flush without big waste of expensive ATF
The rigs and jigs aren’t worth it in my opinion.
When I had record 2008 had transmission service at 40k, from comparison of steel dust on magnets - the 2014 car could have factory ATF at 180k.
Meaning whatever you do is probably more than those transmission really need as the seem to run fine on factory fluid for 200k.
