E-Class (W211) 2003-2009
P0453 error "check engine light" puzzler ?
Old Jun 9, 2018 | 07:47 PM
mikerothacker's Avatar
2005 E500 wagon
P0453 error "evaporative emission control system pressure sensor high input" . I read everything I could in the form and tested everything I could in the car. All valves work the evaporative charcoal canister is not clogged and I replaced the fuel tank pressure sensor. Here is the strange thing, I pulled the connector off of the fuel tank pressure sensor turned the key on with the engine off and checked voltage from the ground wire to the power wire and I have 5 volts I checked the ground wire to the signal wire and I have 4.75 volts. I unwrapped the wiring and looked for shorts , broken insulation I did not find any , I looked closely at the connector and it appears to be fine. With the connector disconnected from the FTP sensor it seems to me there should only be the 5 volts on the one side and not the 4.75 volts on the other side so this is my question could this indicate a bad ECU or could it be something else? Any help would be greatly appreciated. Thanks so much!
Old Jun 12, 2018 | 09:59 PM
2005 E500 wagon
Anyone ?
Old Feb 27, 2023 | 10:08 PM
Pale Writer's Avatar
2005 E320 estate
So this is an unusual specimen, for sure! How do you manage an open question like this that can boast ZERO RESPONSES!?!?!?!?!?
I'm no help - I found this searching for my own P0453 nuisance on my W211!
