E-Class (W211) 2003-2009
Location of Central Gateway module
Old Jun 25, 2018 | 10:00 PM
jockey5678's Avatar
2008 Mercedes E350
Hello, I have a 2008 Mercedes E350, i was wondering where is zentrales gateway or front central gateway module located in my car?
Old Jun 25, 2018 | 11:48 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
Right under the dash on driver's side? Just remove the cover and you will see it.
Old Jun 26, 2018 | 01:52 AM
jockey5678's Avatar
2008 Mercedes E350
I was wondering how do mechanics replace it. I know they program it, but how do they program? And also is the module very inside.
Old Jun 26, 2018 | 10:22 AM
cetialpha5's Avatar
If you're not in a rush and it needs to be replaced, there are companies out there that will rebuild them. That's usually cheaper than buying a new one.
Old Jun 26, 2018 | 01:28 PM
jockey5678's Avatar
2008 Mercedes E350
Any company do you know can rebuild them?
Old Jun 27, 2018 | 01:17 AM
cetialpha5's Avatar
Sorry, couldn't find one, I guess lots of electronics can be rebuilt, but maybe the central gateway isn't one of them. I believe you have to either take it to the dealer to get the new one coded or have a Star diagnostic system yourself to code the new one. A knock off star system is probably in the $600-$1000 range so probably not worth it, plus you then have to figure out how to use it.
Old Dec 14, 2019 | 12:24 PM
Estrada121197's Avatar
W203 Mercedes C240 2003
Where is the location of the center gateway control unit for my w203 c240 2002.
Old Dec 14, 2019 | 03:29 PM
mtrevelino's Avatar
2006 E320 CDI
I would think that if you posted your quested in the right forum, you would get a answer. The forum is located here:
https://mbworld.org/forums/c-class-w203-3/
Mike T.
Old Sep 6, 2021 | 02:54 AM
Samtecq's Avatar
Mercedes c300 2015
Can someone tell me the location of my c300 mercedes 2015 central gateway?
Old Sep 6, 2021 | 11:57 AM
konigstiger's Avatar
'71 Pinto
Post here: https://mbworld.org/forums/c-class-w205-186/
