2008 E350 front end suspension
I have a 2008 E350 with about 140k miles on it. Drive well, with one exception. When driving, even gently, from elevated roads (e.g. parking lots) that dip into the main road, the front end is prone to bouncing down onto the front tires. Looking at the car, the overall ride height in the front seems to be ok (possibly a tad low), but otherwise pretty normal. Is there something I can check / adjust / replace to get the front end solid and "less bouncy". In the old days, would have thought the coil springs were just shot....
Any thoughts or diagnostic suggestions would be much appreciated.
David
I went with Bilstein HD struts/shocks and all Lemforder for the suspension components. Turned out a tas expensive but well worth it.
You wrote "new front lower arms" -- there's two different sorts of arms down there. 140 is called "strut rod" in EPC, and sometimes called a "torque strut". I believe the MB part 140 is sold without the bearing assembly (145/150), but folks like FCPEuro sell it as a unit (arm + bushing assembled). Part 100 is called "Spring Link" or "Transv. Control Arm" in EPC, and FCPEuro calls that a "lower control arm".
