W211 power malfunction
Thank you,
David
So in summary, I would check the condition of the VR first. If the brushes are worn out, replace it with a Bosch VR. Do not use any other brand! Other cheaper VRs will cause problems. Then check the condition of the battery. I do not suspect it is the actual alternator as those rarely go bad.
As for the oil, in the old days you used to change the filter every other oil change but now pretty much everyone changes it with every oil change. You could probably still do that if you're using a Fram Ultra cartridge.
I'll test the voltage regulator, and the alternator. I've got a 1,000 mile trip from FL to VA ahead of me next week, hoping the A/C fan works REALLY well!
Additional input appreciated, and welcome
Stumped.
