E-Class (W211) 2003-2009
Sunroof&interior light not working
Old Jul 22, 2018 | 02:09 PM
Pal Vozar's Avatar
W211
Hi there guys I'm having an issue with my interior light and sunroof they both are gone at the same time and fuses are all fine .Any idea what the problem could be ?
Many thanks
Old Jul 22, 2018 | 02:47 PM
konigstiger's Avatar
'71 Pinto
Recheck f9 @ rear SAM (trunk) - fine, pull for several minutes and reinstall - no change, pull OCP to check underside.
Old Jul 23, 2018 | 01:30 AM
Pal Vozar's Avatar
W211
@konigstiger
Thanks in will try that not quiet sure what you mean under OPC tho?
regards
Pal
Old Jul 23, 2018 | 01:36 AM
Pal Vozar's Avatar
W211
@konigstiger
OCP either sorry 😁 They must have the same problem as nothing on the inside of the roof seems to work .
Old Jul 23, 2018 | 01:39 AM
Pal Vozar's Avatar
W211
I have figured out OCP (overhead control panel)thanks anyways 😁
Old Jul 25, 2018 | 02:01 AM
Pal Vozar's Avatar
W211
Removed OCP and there is no electricity coming in at all any further idea?
Old Jul 25, 2018 | 11:20 AM
'71 Pinto
OCP (N70) is read in directly to rear SAM, pull and check SAM for corrosion. OCP is pin 4 @ connector 22. Worst case scenario harness from rear SAM to OCP may be damaged I believe it is routed up through c-pillar then along left side of headliner.
File Type: pdf
