E500 2004 Battery drain
Is anybody near Katy/Houston area with working knowledge of e500 (2004) who can help. I am having battery drain issue, trunk control won't work, a/c cools and blows hot intermittently.
Will appreciate any help I can get. Going to the dealership for the age of the car is out of the question. And most mechanics don't have a clue and wont let you know upfront. There are a few things I can do myself if I have the right guidance. Thanks.
hey toonday, sounds like you have two/three separate issues going on with the car.
1. I would do a parasitic draw test on the battery and see how many amps the car is pulling when it is off.
2.The trunk control issue, is that from the a. key fob b. trunk release button on the driver door or c. trunk latch release on trunk itself.
3. for the a/c system, has this just started all the sudden, or has this been going on for a while? you might need a simple recharge of Freon, or there might be a leak in the system.
hth
hth
hth
hth
You can get a Southwire DVM from Lowes for about $80, better if you can get your hands on a Fluke with a 10 amp DC feature to measure drain when the engine is off.
