E-Class (W211) 2003-2009
P0300 and P0301
Old Aug 7, 2018 | 03:37 PM
nguyenphananh's Avatar
slk280
P0300 and P0301
Hi, I really need experts' opinion to help fixing my car. 2007 E350 (RWD) with 84000 miles well kept and maintenanced. Last weekend I took the car (with 4 passengers) on the 100 miles, 2 hrs trip up the mountain (over 90F outside). Closed to the destination, the car started to jerk, then losing power. The engine wouldnt die, but no matter how much I stepped on the gas, it wouldnt rev pass 1000 rpm. The car eventually rolled to stop. I turned off the engine and tried to restart, it cranked but wouldnt start. Waited 15 mins later, I tried again and the car started right away, NO CHECK ENGINE LIGHT!! I drove gently for another 10 mins before it happened and dead again. The cycle repeated (no check engine light!?)... Every time the car died, I smelled the strong fuel smell outside the car (no leaking anywhere, I checked). I eventually towed the car home. Right now it is cool and started right away, but pretty sure it wont last long. I used the Icarsoft980 to scan and get the P0300 and P0301. From my research, many people claimed the crankshaft position sensor, some claimed the fuel pump and filter, coil packs, camshaft sensors...etc. Im leanning toward CPS. The problem is even if I replaced the CPS, I wont know if the problem is fixed with my short, flat surface daily driving. Does anybody have any experience with this symptom?? any recommended?? Thank you in advance
