About 600 electronic items remove for 05' W211
I did mention that 04 did not have active headlight., which i don't see any 04 has active headlight in it. It is an option for 05
But that was due to manufacture's decision.
Well.... Take a good look at my 04, It has Active headlights (Feb 04 build date).....
What is wrong? Do you think I provide wrong info to yall?.
The more I hear about the things going on with the E Class the more I wonder if I should keep my 05 E320 CDI when it arrives next month. I have never had such mixed emotions about a new MB. Just venting !!!!
My last benz was a 95 diesel, so maybe I don't know what i'm missing but the 05 cdi is a great car, you won't be sorry
In a word.... Yes.
I don't know what to say, but you are acting like a kid. Tell ya what, manufacture decided when to update the product. Each year they are 2 to 3 production changes. When the starting 04 model which produce in 03 did not have active headlight. It was add on in later production model. You are holding me for something back long while ago.
Not every 04 model have active headlight, which the earlier model of 04 did not have. I post in earlier of the year when there are still no active headlight. Do you know what are the code for active headlight? I bet you don't. Don't worry, I'll give you time to do your research before psoting in here.
Since the first production model and 05 E Class already have some changes. Are you holding anyone to give you information that LAST for a year or two? It is your own responsibility to UPDATE the current information. I am here to provide information for FREE. So keep that for yoruself.
This information doesn't necessary mean bad for MB to cut certain electrical function. The only reason MB did that is base on the current complain of E Class which too many electric function that E class owner having problem with. Some MB decide to cut down the function and make it SIMPLE.
For example, the oil level. The oil level is base on computer to tell, but you always get more or less oil for your car inform by on board computer. There is no dip stick to test the oil level for E class owner, which is really bad.
For tech, to check the oil level which the car have to do loop of dionostic before the result come up. Sometimes the dionositic don't even show anything wrong. Believe it or not, i have see the tech in the back spend 2 to 3 hours still can't find out the oil level for the car.....
I agree with MB which the car have too many electric function that should be cut down and make it simple. The electric function doesn't necessary mean the consumer will miss what you pay for. MB mainly trying to improve the quality of the automobile with less visit to your local MB service center.
Well I guess its true, you get what you pay for....
Barry, I agree with you about the "having to push and hold" the memory feature. This one puzzled me too. Why not just push once like the express windows and sunroof? My only idea is that perhaps in an overengineered kind of way it was intended to be differentiated from the simple press-once feature involved in setting the memory.
MB did not inclosed every list of detail on the bulletons, so i'll try to find out more. BTW, the source of informaion wasn't from some article or magazine review. It is from MB direct. It doesn't tell us what exactually what will be elimate or changes.
Push and Hold on the memory seats prevents a very severe setting from mistakenly being applied - say someone 5'0 tall has setting 1 applied and someone 6'5 presses that setting - it could be painful with no way to stop the setting from being applied. With push and hold you could sense that something wasnt right and stop the motion of the seats...!
Absolutely, spot on. Can you imagine someone being pulverised through the steering wheel like some giant potato mash ?
this is one in my e39 -- one touch memory seat setting.
actually, driver seat should be ajusted to the right position after you disarm it from your remote. (why should I need to HOLD the button for adjusting my driver seat when I have told you who I am ???)
why does mb remove 600 electronic items? because they do NOT work as they are expected.
a correct solution: fire 600 electronic engineers and hire them from lexus or infiniti electronic departments.
it saves time and you can drive car right away.
why not?
I've seen people do this even while holding the seat adjustment... down down down down CRACK.
-s-
Your comment makes sense, but unfortunately not for our car. Easy entry/exit feature works sporadically since purchase (10 months ago) and keys don't always remember the settings. Many times I have to crawl halfway into the seat, insert key and use the M button to adjust the seat before fully entering. As for why this is still a problem, comments for another thread...
