transmission fluid level check
It it is a pain as the dipstick says 25C and 80C which sort of means cold and hot; however, immediately after running through the gears it is above 25C. I used a thermocouple down the dipstick tube to get temp. Then I ran the engine parked in drive until I got 80C. Then I added fluid and rechecked. With two people, you can get it fairly quickly but you need to work together as the correct level is very temperature sensitive.
I assume the Star system monitors temperature and fluid level electronically and let's a mechanic get it right easily at any temperature.
Good luck,
Peter
There is no ATF level sensor on any of those transmissions. You have to get your fingers dirty.
