E-Class (W211) 2003-2009
Adding an MP3 player
Old Jun 8, 2004 | 10:44 AM
spubar's Avatar
What are my options as far as adding an MP3 player to an 04 without the command system?
The car is a lease so I would like to do it the easiest and cleanest way possible.
Old Jun 8, 2004 | 12:12 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Where are you located that you have a 2004 model without COMAND? What radio is installed?
-s-
Old Jun 8, 2004 | 01:08 PM
spubar's Avatar
im in NY. I thought Command was navigation?
Old Jun 8, 2004 | 04:14 PM
scorchie's Avatar
COMAND is the big screen in the dash on all US-spec 2004 E-class.
Navigation is the DVD-device in the trunk.
-s-
Old Jun 8, 2004 | 04:30 PM
spubar's Avatar
Ok well I have Command then.
Now how do I play MP3s?
Old Jun 8, 2004 | 06:47 PM
ctemkin's Avatar
2003 E500
The following is based on my experience with installing an XM radio in a 2003 model, which has the central screen but not comand.
Take a look in your glove compartment. If there is a connection which permits you to insert an audio plug, that would be the best way to connect the MP3 player to your sound system. The sound system should let you select "aux", which would then run the output of the MP3 player through the sound system. You could use the MP3 player on a temporary basis, or you could have one permanently installed, in which case you might well want to use the services of a professional installer. I believe that you can get a feeling for this by searching the forum for satellite radio, MP3, and ipod; also look in the electronics forum.
Unfortunately, my glove compartment was bare. I had to have the installer hook up the XM radio by using an RF device, which essentially broadcasts the signal into your radio's antenna. You access the signal by tuning the radio to the frequency used by the RF device (there will be a choice so as to avoid interference with actual radio stations). Theoretically the sound isn't as good as if there were a direct connection, and you presumably will have to have a professional installer do the work, but in fact the sound is quite good, and this solution has worked out well for me.
Good luck.
