E-Class (W211) 2003-2009
Error 9092 Component G1/7(Auxillary Battery)is defective or not installed. Current &
Old Sep 27, 2018 | 08:18 PM
Shalinder's Avatar
2006 E200 Kompressor , 2015 C200 Avantgarde
Arrow Error 9092 Component G1/7(Auxillary Battery)is defective or not installed
2006 W211 E200K Gasoline model has error 9092 G1/7(Auxillary Battery)is defective or not installed,
scanned on MB11 diagnostic tool, Red light with battery symbol on in dashboard, replaced auxillary battery part no A2115410001 12V 12AH 170A(EN) with Kinetik APTX14 12v 12ah 200cca battery but error still there, auxiliary battery cut out relay K57/2 looks fine & BCM seems working fine & also voltage regulator(Altenator) is charging well, Now shouild I replace Battery with OEM battery or else.. your help in this context will be highly appericiated.Thanks
Old Oct 2, 2018 | 09:21 AM
Shalinder's Avatar
Talking
Thanks everybody for taking a look at my post. The error was found, it was caused by mice brittled wire of auxiliary battery fuse F30. Now everything working fine,Happy driving..
Old Aug 14, 2019 | 11:48 PM
mhebb123's Avatar
2006 CLS500
Where is this fuse located?
Old Aug 15, 2019 | 10:44 AM
konigstiger's Avatar
'71 Pinto
Old May 11, 2020 | 06:09 AM
verlin samonte's Avatar
E200 2002 kompressor
im experiencing this intermittently, example if i start the car now, i get this 9092, after couple of minutes of driving if i restart the car, no malfunction . anyone having same experience, aux battery is low... at 11 volts .... but when i restart aux bat is still at 11volts but no more malfunction
Old May 12, 2020 | 06:59 PM
mhebb123's Avatar
2006 CLS500
Fix for me was new alternator. OEM Bosch. I had an aftermarket that seemed to test ok, but went with OEM and has been fixed.
