Airmatic Suspension
Airmatic Suspension
hello I have a 2007 GL 450. I replaced the airbag on the driver side. Ever since I did that the truck won't lower on the driver side. What could the problem be?
You might get a better response if posted in the correct forum. Regardless, what did you replace the airbag with? An OEM air spring, or aftermarket such as Arnott?
