E-Class (W211) 2003-2009
I have a 2011 MB w212, 200E. The air bellows are flat. The compressor is working.
Old Oct 24, 2018 | 06:21 AM
Petterepost's Avatar
MB 200 E 2011
Run a diagnostic: "overpressure valve C155E13"
What is wrong?
BR
Petter
Old Oct 24, 2018 | 11:13 AM
konigstiger's Avatar
'71 Pinto
https://mbworld.org/forums/e-class-w...ompressor.html
BTW should be posting here: https://mbworld.org/forums/e-class-w212-109/
Old Oct 26, 2018 | 08:41 AM
MB 200 E 2011
Hi!
Thank you very much.
My car MB w212, 200 E - class, 2010 had the same problem. Both Air bellows was flat. It happens the first night when the temprature was -2,5 C. The days before the temprature was about +14C outside. Low temprature makes bad wires to malfunction.
Diagnose: "C155E13 pressure relief valve"
The pressure relief valve for the system pressure has a malfunction. There is an open circuit.
I my case it was the red wire that was broken. I just pulled hard first the green wire, that was not broken. When I pulled hard on the red wire it came lose. Clearly the red wire was broken. I just connected the wires back and started the car. The air bellows raised and the problem was fixed.
Thank you.
