m272 engine noise can anyone tell me what it is?
Long term effects would be that eventually the lobes become so worn that valve lift is reduced to the point of it affecting the combustion process, causing reduced performance/driveability and increasing hydrocarbons because of an inefficient mixture burn affecting the O2 sensors and tripping the MIL lamp. The other issue is the cam adjuster failure which will affect timing and and also throw a code because timing can be altered.
had Mercedes tech listen to it he said its ost likely the main bearing... and that for a 2006 its normal first year production bs and I shouldn't worry about it...
but I find that a bit suspicious... a main bearing making noise that I shouldn't worry about
Did you ever get this figured out? I have pretty much the same sound on my son's E280 (3.0L M272 engine). I replaced all the cam followers since that's what a mechanic told me it was, but it didn't fix the problem (although a few of them were not in great shape). I'm thinking connecting rod bearings, but I won't be sure until the engine is out. I'm leaning towards finding a wreck and replacing the engine.
Here's a video of my engine:
Thanks,
Miles
My engine was burning oil because one of the cylinders had scoring in the cylinder wall. I decided to replace the lower block for a another used one. In the process I found two valve followers with a problem and replaced them. One had a squared roller and the other was missing the spring that holds it to the tappet. The noise is less now but not completely gone. I will keep driving it the way it is now.
While in there I checked for play on the rod bearings and did not find a problem there.
Hope this helps.
Regards Frank
You can try oil additives to fix it (like I will do tomorrow) and if that doesn't work you can replace on/some hydraulic tappets.....or just leave it like it is.....it's just annoying...
I cannot find any documentation on how to replace the tappets on a M272....on some engines it's simple and you only need a simple special tool....on others you have to remove the camshafts.
BTW: I checked the timing chain and balance shaft yesterday and the are in great shape.....my SLK350 has 270K km on the clock and is running fine...only a light tick on driver side near firewall....I can live with that if it is too much hassle....but I want the old girl perfect!
I do need to scope my pistons to see how the walls look. I would think if it were a rod bearing it would knock more when you rev the engine, but it pretty much disappears with the slightest of revs.
https://www.youtube.com/watch?v=87id95J0KCg
I think it sounds fine...
One of the videos [from another member] it clearly sounded like lifter tick. I haven't run into that issue on these motors, but on some inline 6 BMWs the lifters should get "sticky"/gum up and not fully expand with oil pressure. Usually due to some combination or using dino or long drain intervals, short trips, anything that caused excess deposits and varnish... Usually running a good synthetic like M1 0W-40 for a few short drains intervals (like 1000 miles or less) would clear it up. Also holding the RPMs elevated at say 2-3k would free them up as well.
I'm sure you're right that it's normal and not worth worrying about, but man that noise is embarrassing. It sounds like rod knock (though I know it's not). It'll make selling it more difficult once the time comes too.
I've been changing the oil with M1 twice a year for two and a half years at this point so I've given up hope that something sticky just needs to be freed up. I only put on a few thousand miles between oil changes.
I tried Liqui-Moly Pro-Line Engine Flush right after I bought it hoping that would help with no result, too.
