E-Class (W211) 2003-2009
03 e500 exhaust
Old Nov 27, 2018 | 09:31 PM
TSENIOR's Avatar
03 mercedes e500 5.0 v8 04 honda accord 3.0 v6
03 e500 exhaust
Hi i have a w211 03 e500. Rwd. Has 230k original miles and runs drives shifts like new. The only issues ive had are airmatic suspenion which i swapped out for bc racing coilovers. Br series. And other issue is exhaust broke apart. Ive fixed everything other than a few minor tweaks but now i want to hear the v8 a little more. I want to keep both cats. As i have no dash lights at all. And i would like i quiet-ish idle. What im considering is. Resonator delete with factory mufflers for now then e55 or e63 once i get bumper cut out. Or muffler delete, capped j pipe and keep resonators. I want to hear the v8 when i want to hear it but normal driving still quiet. Any thoughts or opinions would be awesome. I know its not a amg. I dont want to spend 3- 4k for what i can have a shop do for a fraction of the price. Im 25 with 2 kids. And this is my weekend driver. Little background.
All factory. Plans are exhaust, eurocharged ecu and tcu tune, needswings intake, drilled slotted rotors and thats about it. Goal is 350 whp (400-450 to the crank) so might end up doing more. Quick reliable weekend cruiser.
Old Nov 28, 2018 | 08:54 AM
Bahnstormer's Avatar
2010 E63 AMG, 2003 E500
Here's my 2003 E500 with E55 AMG mufflers, Renntech carbon fiber airbox, Eurocharged mid-length headers and ECU tune, resonator delete with X-pipe.
Quiet at idle and cruising but nice throaty rumble when stomping on the gas.
Bumper cutouts done by the muffler shop using my Dremel tool, contact paper and template.
Old Nov 28, 2018 | 02:27 PM
e350forme's Avatar
fleet
much info on this forum, but consensus is cut the resonators out and X pipe. different mufflers are a plus too if able to source some from a salvaged AMG
Old Nov 30, 2018 | 02:05 AM
TSENIOR's Avatar
Thanks for the replys fellas. So resonator alone isnt enough i see. Were you able to get one fabbed up at a shop or do you buy one already built. Also eurocharged headers was their any gain in power also sound? Also ecu tune was this worth the money? Thanks for replys.
Old Nov 30, 2018 | 03:00 AM
TSENIOR's Avatar
also did you get a dyno tune or tune from hand held tuner or similar?
Old Nov 30, 2018 | 03:14 AM
Davo81's Avatar
'03 E500
You don't still have your front air struts, do you?!
Old Nov 30, 2018 | 04:59 AM
TSENIOR's Avatar
unfortunately i dont. I sold most in package deal. I still have front motors for air suspinsion. And little diverter vavle box or w.e its call and all that goes with it. If thats any help to anyone. Let go of cheap.
Old Nov 30, 2018 | 05:10 AM
Davo81's Avatar
'03 E500
That's ok. Thanks anyway!
Old Dec 1, 2018 | 07:39 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
You need a tune if you put headers on the car.
Old Dec 3, 2018 | 03:03 AM
TSENIOR's Avatar
Ive already got my quote from eurocharged cincinnati for my ecu and tcu dyno tune. Just curious if the headers are worth the extra $$$.
Old Dec 3, 2018 | 05:49 AM
For sure it's worth it to do headers - the stock manifolds are VERY restrictive.
Your engine will breathe a lot easier and you'll notice a profound difference starting at around 2,500 rpm when stomping on the gas.
Mid-length headers alone are good for an additional 20-25 rwhp.
Together with the tunes they'll totally transform your car.
Enjoy.
Old Dec 4, 2018 | 03:18 AM
TSENIOR's Avatar
Enjoy.
thats awesome to hear! So between the needswings intakes, eurocharged dyno tune and headers. This should be right at 90whp in gains. Maybe more if i do all bolt ons before tune. That should put the e500 right at 375whp. 425hp to the crank. Thats quite a big power jump. Defenitly gonna continue with my preventive maintenance before i start throwing more power at it. If you dont mind me asking... What did they end up charging you? Did they install? Did you dyno tune aswell, if so would love to hear the numbers!
Old Dec 4, 2018 | 07:40 AM
90 whp in gains I think is a bit excessive, and they're really not all cumulative.
​​​​​​If you want to calculate them separately, here's what I would estimate for horsepower increases at the crank.
Headers: 25 HP
Intake: 10 HP
AMG mufflers and resonator delete: 10 HP
ECU tune: 25 HP
Total gains: 70 HP at the crank.
302 + 70 = 372 HP (almost in E550 territory).
I never dynoed my car but these would be my best guesstimates.
Just purchased a Dragy device and once I get new tires I'll check out my zero to sixty time.
Hoping for 5 seconds flat.
