E-Class (W211) 2003-2009
2007 E550 TPMS Question
Old Dec 3, 2018 | 06:10 PM
kss86's Avatar
2007 Mercedes Benz E550
I have a 2007 E550. Looking at the manual it says you can get to a display on the center gauge screen by going to the panel/menu with the temp as the initial display, then press the steering wheel control up button until it gets to the tire pressure monitor. I tried this and it cycles through a few things before returning back to outside temp, but none are the tire pressures. Was the tire pressure monitoring system optional or standard on 2007 E-classes?
Old Dec 3, 2018 | 07:46 PM
jimbo1763's Avatar
2007 E350 Sedan
It was not standard on my 2007 E350.
Old Dec 3, 2018 | 08:00 PM
kss86's Avatar
Ok cool. Thanks for verifying for me! Thought I was going crazy. I'll just have to go old school with the classic manual tire pressure gauge.
Old Dec 3, 2018 | 08:07 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
You don't have any menu with TPMS?
My 2008 model has TPMS, but will not display pressure on the cluster. I only get reset mode in the menu.
But scanner will read actual pressure and will even show temperatures.
How crazy.
Old Dec 3, 2018 | 08:09 PM
kss86's Avatar
How crazy.
That is real crazy if they have that data and dont expose it to the driver. My model year 2007 manual has instructions to pull it up and a picture like this:
Just.... can't get to it how it says so it just must not be a standard feature.
Old Dec 3, 2018 | 08:13 PM
kss86's Avatar
ah man, think I found the answer. it was on a separate page. seems advanced TPMS is only on canada models....
Old Dec 3, 2018 | 09:22 PM
kajtek1's Avatar
Manual doesn't automatically says you have the option.
Use datacard like https://www.vindecoderz.com/EN/Mercedes-Benz
to see if you have it.
Could be PO did not want to spend money on sensors and deleted the menu.
Old Dec 3, 2018 | 09:29 PM
kss86's Avatar
It does seem to say pretty explicitly that the advanced tpms was only available in Canada which my car did not originate in. But I did type my Vin on that site and the only thing containing ''tire" was
633 - LA 17" 5 SPOKE DESIGN WITH WIDE TIRES
690 - EMERGENCY SPARE TIRE (MINI SPARE)
Nothing about TPMS either. So I guess it's safe for me to assume there is no tpms, or if there is it is at least not the "advanced" one that can be viewed via the center guage display...
