FYI: No need to remove oil cooler/power steering tank when replacing camshaft magnets
* You need need the E8 size wrench to remove the bolts.
* Both camshaft sensors between the cam magnets need to removed, doing this gives you clearance to turn the wrench
* When removing the camshaft magnet behind the power steering reservoir, the power steering reservoir CAP needs to unscrewed and removed, if you do not remove the cap the magnet will not be able to slide out.
Hopefully this helps someone!
