E-Class (W211) 2003-2009
07 E350 left & right engine mounts the same?????
Old Dec 13, 2018 | 07:29 PM
racster's Avatar
2007 E350 base
Exclamation 07 E350 left & right engine mounts the same?????
Need to replace engine mounts and after research settled on Lemfoerder parts and they show for my 07 E350 base two different part numbers: 211-240-26-17 for the left and 211-240-27-17 for the right. I ordered them and received two parts both matching part number for left side engine mount. I contacted the vendor and tried to get them to ship me a right side mount and allow my return of the second left mount. They have now concluded that there is no difference between the left and right mount? Can I accept that or do I need to hold firm and request the right mount part that they are advertising. Help anyone?
Old Dec 13, 2018 | 07:58 PM
racster's Avatar
2007 E350 base
Vehicle is E350 Base, not 4-matic
Old Dec 14, 2018 | 11:15 AM
dungey's Avatar
2004 E320 4Matic
Racster, I don't know the full answer to your questions, however, I want to give you some insight on what I am dealing with right now pertaining to the engine mounts. I have two different engine mounts put on by my mechanic and I am experiencing idle vibration that was not there before. Based on the information that I've researched it sounds like the engine mounts and I believe a transmission mount is the cause of this problem.
I am dealing with constant back and forth and hoping my mechanic can solve this issue.
Also apparently there is a difference between idle vibration and rough idle. Where idle vibrations is when your vehicle is stopped however engaged in drive and the rpms go below a threshhold causing a vibration.
D
Old Dec 14, 2018 | 01:35 PM
racster's Avatar
2007 E350 base
Dungey, thank you for that helpful information. I understand the concern and I've just talked to my mechanic who also believes the right and left mount are not the same - and I'm hearing you on your experience. To resolve this situation, I'm planning to return both Lemfoerder mounts to the recalcitrant vendor and get two Corteco mounts (L & R), as Corteco, like Lemfoerder, is also an OEM suoplier for Mercedes on these mounts. I appreciate your response!
Old Jul 27, 2019 | 09:10 PM
Marxs's Avatar
c220 cdi w203, c200 w202, ML 320 w163
Engine mounts the same.
From what I can gather the engine mounts are the same, however the right comes with the heat shield that protects it from the exhaust pipe.
Old Jul 29, 2019 | 05:03 PM
e35008's Avatar
08'e350
yes, they're the same.. had the same questions when I DiY mine. turned out they're identical
