E-Class (W211) 2003-2009
Wire / cable of fuel pump
Old Dec 18, 2018 | 08:17 PM
a1706a's Avatar
w211
Hello friends
Mercedes Benz CDI E220 W211 Year 2005
I wanted to know where is the cable / wire of the fuel pump
I want to connect a GPS Tracker with a fuel shut off relay so i need the connection of the fuel pump. And I need a drawing of the fuel pump. And where the cable of the pump is located
If possible please send me a drawing / explanation where the cable passes the gas pump
Old Dec 22, 2018 | 04:48 PM
a1706a's Avatar
w211
Old Dec 23, 2018 | 12:29 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Pelican Parts tech article on W211 fuel pump.
Old Dec 23, 2018 | 11:57 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
On cdi the high-pressure fuel pump is mechanical.
There is small electric priming pump, but I doubt cutting power to it will kill the engine.
So you need to do more research if you want a kill switch.
Old Jan 1, 2019 | 09:33 PM
a1706a's Avatar
w211
I have disconnected the electronic fuel pump fuse and tried starting the car, it didn't start. Once i have put the fuse back it started immediately.
So i guess, disconnecting the fuel pump would shut off the engine while running.
My next step is findind the fuel pump wire (12v and ground) so i can connect it to the relay
Old Jan 1, 2019 | 09:34 PM
a1706a's Avatar
w211
Old Jan 2, 2019 | 12:22 PM
kajtek1's Avatar
I wouldn't bet on it. Priming pump is definitely needed for priming.
Once the main pump is running it MIGHT create enough suction, that it works without priming pump.
Pull the fuse again with engine running
Old Jan 14, 2019 | 07:20 PM
a1706a's Avatar
w211
I have disconnected the fuel pump fuse while the engine is running, then the car started running rough and eventually the engine stalled. This means that the GPS with a fuel pump shut-off will work.
Next step is to find the fuel pump feed link and ground line
Old Jan 19, 2019 | 08:45 PM
a1706a's Avatar
w211
Old Jan 23, 2019 | 09:39 PM
a1706a's Avatar
w211
I need to know where the wires of the fuel pump are. To connect the Gps Tracker. I need to know where the wires go. To connect the GPS tracker
(I attach the link I bought to the Gps Tracker)
https://www.aliexpress.com/item/Mini...OrigTitle=true
Old Jan 27, 2019 | 05:42 PM
a1706a's Avatar
w211
Can you tell me please where is the cable of the fuel pump? I want to connect the gps tracker. And I can not find
Old Jan 27, 2019 | 11:27 PM
kajtek1's Avatar
you have pump plug under rear seat. Take probe light to determinate correct wire, but it has to be thicker one.
Old Jan 28, 2019 | 06:41 AM
Maroc_Specops's Avatar
W211 E320 CDI Sportpackage With Carlsson CD32 Chip 2004
Thats a lot of tracking research for a 2000 dollar car
Old May 20, 2020 | 07:27 PM
Jub's Avatar
Jub
E55
Hi, did you find out what cable to use for the gps kill switch? I'm looking to do the same on my E55 and I can't find how to do it. Thanks
Old Nov 22, 2021 | 11:06 AM
DuhStig's Avatar
E320 CDI
You pretty much answered your own question. You found the fused link, you can disconnect the fuse panel and locate the wire or wires that feed the fuse. Then you can choose to cut there or back probe the wires to the fuel pump ...
Old Nov 23, 2021 | 09:12 AM
DuhStig's Avatar
E320 CDI
This article pretty much answers your question.
https://www.pelicanparts.com/techart...mp_Testing.htm
Brown is ground Red is +!2v I looked on my E320CDI it's the same . Now you just need to figure out where you want to cut the wire and add your kill switch . Best of luck!
