E-Class (W211) 2003-2009
P0128 Thermostat Error
Old Dec 20, 2018 | 11:30 PM
lyonsfin's Avatar
2009 E350 4matic wagon, 1980 450SL, 2011 GL450
I got a check engine light on my 2009 E350 wagon. Car was driving fine so I read the code-P0128 thermostat not closing- I reset and have driven over 200 miles with no CEL and no issues. Temperature gauge reads 80-90 degrees C before, during , & after CEL came on. Temperature appears to be very steady.
Any insight or just an anomaly as the car had sat about 4 weeks prior to this episode.
Old Dec 21, 2018 | 10:09 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
Does your car seem to take longer than normal to warm up?
Old Dec 21, 2018 | 11:57 PM
lyonsfin's Avatar
I don't think so. 2-3 minutes before gauge begins to read 40-45 degrees (50 degrees F ambient) Full temp within 3-5 minutes & 3-4 miles.
Old Dec 22, 2018 | 10:11 AM
2013 ML350 Bluetec
I'd just drive it, while observing warm up times. I let my car sit for the month of November while I was out of country. The glitch I noticed was the windshield washer fluid did NOT work for a couple of ignition cycles. Push the stalk halfway, the wipers wipe like you'd expect. Push the stalk all the way to the fluid dispenser position, it was just like pushing halfway: The wipers would stop after completing one cycle after releasing, and no fluid would come out. The problem went away as quickly as it appeared and hasn't been seen since early December.
Anecdotal evidence, for sure, but... Just drive it. If it happens again, take action.
Old Dec 22, 2018 | 10:33 AM
lyonsfin's Avatar
Thanks. That's kinda always been my philosophy! If it isn't "self-healing" then I delve more into it!
Old Dec 30, 2018 | 07:37 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Thermostat is likely sticking, recommend removal for inspection and coolant replacement.
This is an electric assisted thermostat so it is a bit pricey if it fails.
Old Jan 1, 2019 | 04:20 PM
cetialpha5's Avatar
It's very common for them to go. I replaced the one in my 2008 several years ago. OEM is a Wahler. I think I got mine on Amazon for around $70. It actually has the spot where the MB logo would be blurred out. It was pretty noticeable on a cold day, car never really warmed up beyond 80. Now it's usually at least 90+. You might also want to check your pulleys and tensioners, those are also common failure items on the M272. I replaced mine at the same time as you have to remove one of the pulleys anyway in order to change the thermostat. I think the kit is around $122 on rockauto.com. There's also a discount code on retailmenot.com that takes off 5% so that kinda pays for the shipping.
https://www.rockauto.com/en/moreinfo...=1443226&jsn=2
Old Jan 3, 2019 | 01:34 PM
05w211wagon's Avatar
2005 e500 w211 wagon
have you tried using a temp gun on the hoses to double check?
