E-Class (W211) 2003-2009
Coolant level check after thermostat replacement
Old Dec 21, 2018 | 02:32 PM
kxrider375's Avatar
2011 e550 cabriolet
I got the CEL and the code scan called for a thermostat issue....so I figured replace it and should solve problem. So after replacing it I now have this coolant level check and the engine light is still on....
it never actually showed running hotter than the normal temp so not sure what it could be at this point. Is there a coolant level sensor that maybe has gone out?
Old Dec 21, 2018 | 11:24 PM
ot1's Avatar
ot1
2006 E320 CDI
Originally Posted by kxrider375
2011 e550 cabriolet
yes there is a coolant level sensor In the overflow tank and so after you changed out the thermostat I’m sure you brought the level back up to where it supposed to be, right? I found the blue coolant for my vehicle was actually cheaper, and BLUE, than at the auto parts stores.
