E-Class (W211) 2003-2009
Help E350 Differential Bearings
Old Dec 22, 2018 | 03:50 PM
caseybalbachan's Avatar
w211 e350
HI, my pinion bearings went out in the diff of my 07 e350 rwd. Does anyone know if the differentials in the 4 matics are the same oness used in the rwd? I find the bearings online but the postings say for 4matics, anyone have any idea if they are interchangable? Thanks
Link: https://www.ebay.com/itm/07-08-09-Me...74ac%7Ciid%3A1
Old Dec 22, 2018 | 08:07 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
What are your qualifications for differential rebuild?
Not too many shops attempt such repair, so it is definitely beyond DIY scope
But anyway, if you really want to go for it, get full WIS for the job as adjusting the clearances and torquing is critical.
The WIS will also tell you bearings sizes and shims you might need for the job.
Good luck.
Old Dec 26, 2018 | 07:04 PM
w211 e350
Good luck.
ASE certified, rebuilt diffs, engines from the block etc when I was a mechanic. Got the clearances and torques from WIS but no part numbers on the bearings from EPC and couldn't source them anywhere and didn't want to match up bearings at a shop. Found out bearings used in the 4matics but the diff seals for the 4matics and RWD are different part numbers, so I'm guessing the diff housings are different (or maybe not, didn't want to gamble). So bought a used diff with 80k and swapping out!
But thanks for the help.
Old Dec 26, 2018 | 08:54 PM
isosunrise91's Avatar
Lexus IS
I had my rear diff rebuilt by group (so to speak) who is selling that bearing on eBay. They are in westchester New York. I spent a fraction of what it would have cost to buy a used rear diff plus install.
Old Dec 26, 2018 | 11:50 PM
kajtek1's Avatar
Did you check ebay?
I was rebuilding Ford differential about 5 years ago and there was a company in Las Vegas who specialized in rebuild kits.
They gave me excelent price on gears and Timken bearing and top it with overnight free shipping to CA, while gears for Dana 80 were pretty heavy.
Old Dec 27, 2018 | 01:25 AM
w211 e350
Did you check ebay?
I did check but didn't find any that said they were an exact fit for an E350 RWD. All were for 4
Old Dec 27, 2018 | 01:26 AM
w211 e350
Was yours a 4matic?
Old Dec 27, 2018 | 11:50 AM
Lexus IS
Yes mine Is 4matic however, message the Ebay seller his name is Jerry.
