Audio system nightmare
I had rca outputs installed on my original stereo to accommadate the amps and subwoofer upgrade. A local shop installed 2 JL amps and a Image Dynamic ID4 12 sub with a set of Phoenix Gold Elite 3 ways in custom built floor pods. It worked great, but the stupid auto sound level adjuster keeps raising and lowering my volume. I couldnt get it to stay the same, it just goes up and down all the time and at higher volumes the stock deck distorts like crazy. I wanted navigation but didnt want to spend another 3k on the command unit and then have to deal with the auto volume and distortion, so I opted to go with the new Pioneer N1 navi/dvd/cd unit. Thinking it would be a synch to swap out like my past benzes, I had the shop pull the stock deck and build a new trim plate to install the N1. Please beware, that the 03+ E class is all digital and optical. Apparently the shop tapped a wrong wire, they got the unit to work but my sunroof, doorlocks, power windows, ac controls all stopped working. Plus the stock ignition is also digital so now they couldnt tap the turnon lead from the new deck into the ignition and it got tapped into a constant power, ending up draining my battery. Now the car is at Topline, the famous bay area Benz troubleshooter, who has had it for over a week now trying to figure out the codes and wiring problems and trying to fix everything. This install and troubleshoot job is going to cost me well over $1000. So before you guys start pulling out the stock deck or commands, find someone that has had experience with 03+ benzos and know how to bypass oem digital and optical wiring, or else you are going to have some serious issues and problems. The car should be done this weekend or next week, Ill post pics then.
