E-Class (W211) 2003-2009
Heater Smell and some questions
Old Jan 15, 2019 | 11:03 AM
DBurbach's Avatar
E320 CDI
Hi everyone, I'm new to the forum, and new to MB ownership too. I just bought a 2005 E320 CDI and I have a couple questions.
1. I'm getting an slight burnt smell from the vents when the heater is one, any ideas?
2. I can't for the life of me figure out how to lower the passenger seat headrest. The driver's seat is electric, but the passenger seat has a dummy button for the headrest and I can't figure out how to do it manually.
Thanks everyone, excited to be a part!
Old Jan 15, 2019 | 06:26 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
If the button for the headrest adjustment doesn't work, a bit of diagnostics is in order. It's not a dummy button. There isn't a manual adjustment. If you wanted to get jiggy with it (set it and forget it) you can take the back of the passenger seat off and see what you need to do to move it by hand (spinning some gears with a screwdriver?).
Re: the burnt smell, there's an auxiliary electric heater built into the HVAC system that supplies warm air when the engine is still cold. That may have some crud built up on it, or it may be burned out. When you first start the car in the morning can you get warm air out of the vents? Pushing the "AC OFF" button will light the red indicator light on the button and will disable the auxiliary heater.
Old Jan 16, 2019 | 08:02 AM
DBurbach's Avatar
E320 CDI
Thanks, I'll give both of those a try!
Old Jan 14, 2021 | 09:21 PM
PVC_ZX11's Avatar
2008 E350 4Matic
Anyone know where the auxiliary motor can be found on a 2008 E350 4Matic sedan?
Old Jan 14, 2021 | 11:28 PM
rocky472's Avatar
Two 2005 E320 CDI, 2004 E500 Wagon, 2007 ML63 4MATIC
I had the same burning oil smell with my 05CDI. The issue for me was a leaking oil separator and cap. Oil was draining down the right side of the engine and collecting on the tray/heat shield under the air filter. There is a drain hole in the tray that is directly above the catalyst which was the source of the smell. I first tried an aftermarket oil separator which had bad plastic welds and leaked from the top of the chambers. The fix was to buy the genuine MB part. Thankfully Pelican gave me a credit which I used for other parts. There are many MB dealers that discount parts so shop around for the best price. I have used Suburban MB in Ann Arbor MI and Keys MB in Van Nuys CA. The cost difference was negligible between the two parts I bought and I have been leak free for the past year.
Old Jan 30, 2023 | 03:09 PM
steliosgmich's Avatar
w211 2008 E200
hello i have the same smell in my E200 W211 2008......any photos from the part you changed ??
Old Jan 30, 2023 | 03:10 PM
w211 2008 E200
