E-Class (W211) 2003-2009
2007 E350 - Navigation Disc
Old Jan 19, 2019 | 11:04 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
The Navigation Disc on my recently purchased 2007 E350 is missing in the trunk Navigation CD Unit/Player.
Anyone have a decent source, as to where to obtain a disc? Would EBay be the right place to shop for? I sure do not wish to pay dealer prices.
Assuming the CD goes into the trunk unit, and stays there?
Thanks very much in advance.
Old Jan 20, 2019 | 09:40 AM
konigstiger's Avatar
'71 Pinto
Search BQ6460338 and/or T1000-23902. Yes, disc loads/remains in navigation module last (current) release 2015-2016 MB NTG1 DVD v15.0
Old Jan 20, 2019 | 10:02 AM
S70Houston's Avatar
Thanks very much Konigstiger.
Old Jan 20, 2019 | 06:44 PM
S70Houston's Avatar
Please excuse my ignorance, assuming this to be only ONE (1) disc. Or does the unit in the trunk hold more than 1 disc?
Thanks for the help.
Old Jan 20, 2019 | 06:59 PM
S70Houston's Avatar
Would this be the correct one:
Old Jan 21, 2019 | 08:36 PM
cetialpha5's Avatar
Well it's correct that 2016 was the last year for the navigation DVD. There's only one DVD in there. It can be found out there if you search for it but I can't post the link. Also that link seems to be a copy anyway as it mentions it's a backup copy. For NTG1, a copy works fine. I think for the newer version of NTG in the 2009 model, you need the original disc.
Old Jan 21, 2019 | 09:01 PM
nguyenphananh's Avatar
slk280
search on this forum, there is link to download both the update and the map disc. Remember to burn it at slowest speed (1x for me) and good quality disc
Old Jan 21, 2019 | 11:43 PM
S70Houston's Avatar
I ordered the below disc on eBay.
So based on your statement, I must assume what I ordered will work on my '07 E350?
Old Jan 24, 2019 | 12:52 PM
S70Houston's Avatar
The disc I ordered from eBay will arrive today.
So again, please excuse my ignorance, but all I do is insert the disc in the slot in the trunk unit, THAT's IT? Then hit the NAVI or MAP button on the console unit and all should work?
Anything else that may need to get done?
Thanks in advance.
Old Jan 24, 2019 | 01:02 PM
cetialpha5's Avatar
Yep that's pretty much it. It may take a little while to load initially, but give it time to load/do updates and it should be fine.
Old Jan 24, 2019 | 01:08 PM
S70Houston's Avatar
Thanks very much.
Assuming there does NOT need to be any power on the car, ignition on, or does the car need to be running?
Thanks.
Old Jan 24, 2019 | 01:11 PM
cetialpha5's Avatar
Thanks very much.
Thanks.
I would run the car for a while so the system can stay running. I can't really remember it that well, but I recall popping it in and then just driving around for a bit, it was a little flaky at first but then the next time I used the car it was fine.
Old Jan 24, 2019 | 01:29 PM
S70Houston's Avatar
Thanks a bunch.
Old Jan 24, 2019 | 06:25 PM
S70Houston's Avatar
Disc received today!
Inserted/installed into trunk unit.
Works as it should.
THANKS VERY MUCH AGAIN FOR EVERYONE's HELP AND INPUT, GREATLY APPRECIATED.
Old Jan 26, 2019 | 12:58 PM
S70Houston's Avatar
Voice Comand
Works as it should.
Unfortunately, I am not able to turn on the Voice Comand. I would imagine there to be an ON/OFF switch, but after reading through the manual, it appears I am not able to figure it out.
Everything works great, but no Voice for the Navigation. HOW TO TURN IT ON AND OFF?
Any help is greatly appreciated, thank you.
Old Jan 26, 2019 | 01:11 PM
slk280
Im not very sure of your situation, but during the navigation (when its announces street, name), use the volume knob to turn on the volume!! I found out that the volume control for radio, cd, nav..etc... are separated/independent. There was times when the music volume was normal, but the nav volume was turned to minimun.... drove me crazy for a while. I dont remember exactly the step, but there is a button on the comand that activate/repeat the voice comand, press this button during the navigation (for the unit to announce the street name), at the same time turn on the volume control... that will fix it!!
Old Jan 26, 2019 | 01:35 PM
'71 Pinto
See if attachments help.
File Type: pdf
File Type: pdf
Old Jan 26, 2019 | 01:48 PM
S70Houston's Avatar
Many thanks as always. Figured it out, and is now working. Thank you!
Old Jan 26, 2019 | 05:28 PM
S70Houston's Avatar
YES, that is exactly how it works, THANK YOU!
