E-Class (W211) 2003-2009
Door safety lamps (red)
Old Feb 4, 2019 | 03:06 PM
Redwood415's Avatar
92 W124 500E, 93 W201 190E, 11 C207 E350, 05 W211 E55
gents- has anyone experienced their door "safety lamps" or red corner lights on the bottom edges of the doors not working?
I pulled the lens cover and they appear to be LED type. Does anyone know the "proper" name for these door lamps? I am looking to replace but need to know what they are called and what is the removal procedure? Hoping I don't have to remove my whole door panel for this timy corner light? Any help would be much appreciated! Cheers..
Old Feb 4, 2019 | 04:55 PM
konigstiger's Avatar
'71 Pinto
Harness connects to door module, loops in lower courtesy light (110 in diagram) - lamp is 2118201101 (160), lens 2118250510 (170) all doors. See attachments for liner removal, and if needed foil removal for harness check.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Feb 4, 2019 | 07:44 PM
Redwood415's Avatar
Thanks for that. do you know correct name for that LED door lamp? do you know if able to remove w/o removing panel and inner foil? Makes me wonder because LED lamps don't typically fail do they?
Old Mar 24, 2019 | 01:10 PM
Gnaigle's Avatar
2018 GLE350 4matic
Courtesy Lamp
