On center feel
If the dealer is competent, they should do an alignment for you. If not, go to a really good alignment shop (ask a local Porsche club for a recommendation). The $120 you spend will be well worth it. The whole handling will be better.
David
I had mine adjusted. They simply took the steering wheel off and installed it correctly in the straight ahead position.
No change to the alignment was done.
That was probably just fixing the symptom rather than the cause.
