Headlight Level check
Is there somewhere an indication about the inclination of the beam, or a printed grid to help you position the the beams?
Thank you
https://shop.advanceautoparts.com/r/...ust-headlights
Internet search will pull up more info.
Also consider that your front suspension might be miscalibrated (assuming your E500 has Airmatic). If the front suspension is too high, it will lift the headlight beams. Front control arms should be between 3.1* (lowest suspension setting) to 4.1* (highest suspension setting). One headlight apparently angled too high does make it sound like a headlight issue.
Strong up close. The left should be lower for oncoming traffic.
I’ve placed both the W211 and the R230 against the garage door and then backed them about 25 feet. First picture shows the W211 1 ft away, the left headlight is only 1/2” higher than the right. At 25 ft. the left headlight is about 8” higher than the right. They are both way dimmer and higher than the SL.
For easy referral, when I am close to door/wall I put a piece of masking tape on the center of beam.
