E-Class (W211) 2003-2009
Dynamic seat pump "domestication"?
Old Feb 25, 2019 | 05:54 AM
usernamed's Avatar
w211 e500
Hi!
So i managed to get ahold of one 2003 E500 which has dynamic seats, but the pump is missing in the trunk.
Does anyone know whether the replacement pump needs to be domesticated with Star, or will the unit swap just do the trick (with correct part)?
Thanks!
Old Feb 25, 2019 | 10:20 AM
konigstiger's Avatar
'71 Pinto
Ideally STAR should be used to erase stored fault codes & activate however, more times than not plug & play. In addition, after install check f87 @ rear pre-fuse box located next to trunk battery. See attachments.
File Type: pdf
File Type: pdf
Old Mar 1, 2019 | 03:33 PM
usernamed's Avatar
w211 e500
Thanks. I understand there are different part sizes for the pump? Check attachments. How should i know which one fits mine?
Old Mar 1, 2019 | 06:00 PM
'71 Pinto
Compatible part #s:
Old Mar 1, 2019 | 06:06 PM
usernamed's Avatar
w211 e500
Ok. But why are every ebay listing for the second picture and this tutorial for example: https://www.pelicanparts.com/techart...eplacement.htm
Old Mar 2, 2019 | 09:03 AM
'71 Pinto
Reservoir is depicted in photo (part # 2118000019) not pump.
File Type: pdf
