2009 e350 instrument cluser dead
Subscribe
Feb 27, 2019 | 10:26 AM
Car was not used much this winter. (very cold record cold) . was only started to move parking spots Here are details: mechanic says was not able to see the module in software scanner. unit was not able to boot up when power was applied. " tried to start you could tell but it was dim and then stopped." of course, no mention of instrument cluster in warranty, it is probably not covered after the run around.
I drove the car for a solid day, and cluster was dead. turn signals worked, but realized turn signals still work they just dont play the noise on the cluster everyone expects.
Today, car woke up and sure enough the cluster was on, but then cut out. car was not stated at this point.
My plan is to remove the cluster and let it warm up to room temperature. Also, to keep driving the car.
If I need a new cluster: I see there are several for cheap. but the programming is a mystery to me.
Reply 0
Feb 27, 2019 | 02:19 PM
Quote: Car was not used much this winter. (very cold record cold) . was only started to move parking spots Here are details: mechanic says was not able to see the module in software scanner. unit was not able to boot up when power was applied. " tried to start you could tell but it was dim and then stopped." of course, no mention of instrument cluster in warranty, it is probably not covered after the run around.
Do not simply swap in another cluster. Read #6 and #8
https://mbworld.org/forums/e-class-w...ster-swap.html
Reply 0
Feb 27, 2019 | 03:00 PM
looks like It is do-able. w
anything else to do after that is done besides throwing the new cluster with old PCB into my german chariot?
Reply 0
Feb 28, 2019 | 12:22 PM
despite no responses, I will report that the cluster is back to life. I did pay the 200$ for mechanic to scan/diagnose but seems fair as it was not in my capacity to troubleshoot. The car was subjected to extreme cold temperatures. Seems to have come back to life. I will most likely have a spare on hand. aftermarket warranty essentially ignored me. I do have a check engine light, but first time I have seen the cluster light up and work. I dont have a mercedes scanner tool yet, but will try and see if ELM will clear the CEL
Reply 0
Feb 28, 2019 | 12:29 PM
Quote: despite no responses, I will report that the cluster is back to life. I did pay the 200$ for mechanic to scan/diagnose but seems fair as it was not in my capacity to troubleshoot. The car was subjected to extreme cold temperatures. Seems to have come back to life. I will most likely have a spare on hand. aftermarket warranty essentially ignored me. I do have a check engine light, but first time I have seen the cluster light up and work. I dont have a mercedes scanner tool yet, but will try and see if ELM will clear the CEL
Was this car a CPO? Dead cluster in the cold seems to be a common problem on facelifted cars.
Reply 0
Feb 28, 2019 | 02:34 PM
nope, used car lot type of place. The warranty is through GWC.
Can you help answer a question for me? If I swap over PCB in future into a new cluster, what has to be done next to get it working?
Reply 0
Jul 11, 2022 | 12:42 PM
I keep the car in garage in winter now, heated, the cluster does not go out
Reply 0
Subscribe
Currently Active Users (1)
