New to Me 4matic wagon
e500 4matic wagon
Sorry if these pictures are huge but this is my new e500 wagon. Got it last night drove back home about 850 miles. It's got just about 81k miles on it now. Noticed a few things on the trip home which I plan to research more on this forum and others, but figure might as well attached them to my first post
1) Is that too much of a gap between the hood and bumper/ Headlights?
2) car shifted hard twice when rolling to a stop I'll check fluid levels but any other tell-tale signs to look for?
3)I assume this is normal with the electrical gas pedal but I've really gotta give it some input to get going from a stop
4) brakes make a quick sorta hum noise when the pedal is pressed driving or parked
With that being said loving the car so far got 22mpg on the way home which was way better then I was expecting car feels fairly quick might take it to the drag strip when I get all the maintenance and TLC stuff done (probably not lol but maybe)
Also I don't have a button on the drivers door to open the hatch is that normal ? Seems weird to have something like that as an option
2) Your torque converter lockup solenoid is failing and will need to be replaced
3) Throttle reset
4) Your car us equipped with brake by wire SBC brakes. The sound is normal and the system is covered by a 25 year unlimited mileage warranty.
The fact that the hatch button is missing seems weird.
e500 4matic wagon
CarFax has no reported accidents and from what I can tell every thing is straight as far as metal goes more then likely the airmatic pump got replaced then I suppose. I'll see about adjusting the bumper this weekend.
The torque convertor lockup solenoid doesn't appear to be all that expensive so I'll have to see if I'll be able to replace that on my own.
And yeah I'm definitely scratching my head at the lack of a hatch button.
Thanks for the info btw
e500 4matic wagon
Yeah I try to do as much as possible my self. I'll look into those. Although I Will probably take it some where if I have to replace the lockup solenoids as that is looking like a bit more work the I want to do in my drive way. Coming from a VW's I know a few good German shops that shoud be able to do that no problem.
1. There shouldn´t be a gap between front fender and bumper next to the headlight - the bumper is mounted too low.
2. One of the sprags may have flipped, a typical problem of the 722.6 trans.
3. Yes, this is sometimes embarrassing (even with 388 hp), especially when it starts in 2nd in comfort/ winter mode...
4. No idea, luckily no SBC on my facelift-model
Received 4,446 Likes
'71 Pinto
2004 e320 and 99 e320 wagon
I had the same problem with the 722.6 transmission. It would jerk when coasting slowly through a parking lot or when coming to a stop. almost like a downshift. If that is your issue you will need this fix. https://www.sonnax.com/parts/2325-tcc-damper-valve-kit
The install was above my pay grade but it fixed my torque converter problems.
e500 4matic wagon
e500 4matic wagon
I bought a foxwell code reader so it depends on what that says but more then likely I'll be replacing both parts
https://imgur.com/a/8X4RT75
e500 4matic wagon
That's the right call IMHO. TCC solenoid is $28 on fleabay, comes in a Mopar box but the part itself is MB logo and PN. I just finished this job on my 170k mile 722.6. it's really not that bad and it is so damn smooth now in every situation.
Check the base of the gas peddle. Others have stated that the plastic hinge was loose on the bottom and caused the gas peddle to be somewhat latent when pressed down quickly.
Our E500 wagon launches like a rocket whether it is comfort or sport mode when the gas peddle is mashed and drops right into first gear. Otherwise Comfort mode will always start you out in 2nd gear with light peddle pressure. MB used to call it Winter Mode so the wheels would be less likely to lose traction when starting out in the snow.& ice.
