E-Class (W211) 2003-2009
Transmission problem
Old Apr 26, 2019 | 06:41 AM
Ahmed Thamer's Avatar
w211 & c219
Hello
I have problem in my w211 2005 722.906 transmission
The problem start in VGS turbin sensor I bought new VGS and new problem apper When car change from 1st gear to 2nd like a hit or bob I change the hydraulic unit and same problem and I changed all transmission with torque converter and same problem I have star das when I checked no fault codes in the transmission ,engine ,selector and ESP every things is fine but same problem transmission hit
Anyone have same problem or idea
Old Apr 27, 2019 | 01:04 AM
AUTOdidact's Avatar
E500 4matic
If you already changed the transmission, it may not have been the problem
Take a look at the rubber flex plates between trans/driveshaft and driveshaft/differential.
Old Apr 27, 2019 | 03:03 AM
w211 & c219
I change it too same problem
Old Apr 27, 2019 | 10:01 AM
w211 & c219
The problem fixed change transmission control unit again the problem was in the unit
but the old unit ( bought it before 1 week) orginal one not giving any fault in das
