Crazy Battery drain! Please help
So I have a bad battery drain, typically overnight. Fuses #3, 6, 9, 29, 31, 33, 34, 41, and 42 are drawing power after the car attempts to sleep! 33 and 34 I am not too worried about as they seem to be the power seat control module, so I assume I can rewire them to ACC on only or something similar that can be found on here.
3 - navigation/TPMS/
6 - AGW
9 - Overhead control panel control unit
29 - Steering column module/ EIS control unit
31 - Upper control panel control unit
41 - Central Gateway Control Unit
42 - ME-SFI/ Driver side SAM control unit
They also seem to cycle on and off. #29 and #41 are the highest draw at .11
So I am thinking it has to do with the radio/AGW/Headunit perhaps being bad?
Any way to definitively test units one by one or does anyone have any insight or ideas?
Thanks in advance!
Can I unplug the SAM and test for draw etc?
Fuses #
21
22
29
33
34
41
55
64
All of these affected the draw by around .1AMP each. Originally car bounces between .40 - 1.55 Amp draw. With all of these fuses pulled it was still bouncing between .13 - .76
What is causing the readings to continuously bounce up and down and why didnt any single fuse cause that to stop or cause a major drop??
Thanks in advance.
For the first, pull fuses/relays one at a time and then reinsert. For the second, start pulling fuses until it quits. Multimeter with positive to battery positive, negative to BCM
Last edited by bbirdwell; Jun 16, 2020 at 10:28 AM. Reason: Lined out erroneous connection info.
I don't know if you are using this process but here it is:
-Trunk lid open,switch wedged closed position (trunk light off).
-Multimeter tied between positive post and BCM ground point on chassis.
-Key out of ignition. If keyless-go, key shielded and/or outside transmission range to the car.
-Monitor multimeter; waiting maximum of six minutes the bus should go to sleep although it can take as long as 30 minutes for minimum activity.
I find it unlikely both SAMs failed plus a module hanging off of the interior fuse block. What is interesting is you pulled the fuse to the front SAM (F78) and when you pulled the power to the interior fuse block F34, you also killed another source of power to the front SAM (F42 in the interior fuse block). The front SAM is powered by both F78 and F81. The rear SAM is powered by F79.
Put it on a diagnostic system and see what it pulls out of error memory.
) but didnt have much information. Of course that could lead to anything....
I assume this came off due to moving the cables/battery etc and wore off..... What is it exactly for? Also I have the connector apart but cannot seem to get the pins out completely to re-solder the wires on.
Thanks for this thread it is really useful.. I just replaced my battery and have had some unexpected low voltage issues. It sounds like I just need to check that these wires connected to the negative battery terminal are firmly connected?
