E-Class (W211) 2003-2009
New Sirius SAT Radio Antenna
Old Jul 1, 2004 | 11:43 PM
wem's Avatar
wem
‘24 Maserati GranTurismo Trofeo;'22 AMG SL55;'23 Porsche Cayenne S Coupe;'13 Porsche Boxster S
I know a number of people are not happy with the SAT radio antenna on the trunk deck. At least for the 2005 CLK, the antenna is now completely hidden (see my posting on the 209 board). I don't know if the 2005 E will also have a hidden antenna, but maybe there's still hope.
Old Jul 2, 2004 | 01:01 AM
DavidNJ's Avatar
'05 E320 CDI;'04 S2k;'94 Supra TT;'10 QX56;'38 Buick;98 Port City Offset Late Model
Does the CLK have a metal trunk. Some MBs have a plastic trunk and MB puts the sat radio antenna underneath.
Old Jul 2, 2004 | 03:48 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
It isn't "now completely hidden", it has ALWAYS been completely hidden. The W209 cabriolet (ONLY!), and the W215 CL have composite (i.e. PLASTIC) deck lids. W209 coupes have a metal trunk and cannot use that antenna.
-s-
Old Jul 2, 2004 | 08:53 AM
kort677's Avatar
'05 e320 cdi, '05 lexus rx330
Thumbs up
do a search for t bones install, many of us have used this hidden installation on the 211's and it works well
Old Jul 2, 2004 | 10:19 AM
Rudegar's Avatar
2004 E500
Do you think they will eventually come up with a color coded smooth/aerodynamic-looking housing? There doesn't seem to be any reason why the housing has to be a flat black oddly and irregularly shaped dog house.
Old Jul 2, 2004 | 11:29 AM
DavidNJ's Avatar
It was clearly designed by someone who didn't care. Always a dangerous position for manufacturer or vendor to be in.
Old Jul 2, 2004 | 11:43 AM
scorchie's Avatar
Exclamation
I think the criteria Mercedes used in selecting the antenna resulted in what we have now. These criteria were probably:
1) has to actually bolt to the surface for semi-permanent installation; most of the new low-profile ones are magnetic/tape only and the wires run externally
2) price has to be reasonable, which is probably why we have old discontinued technology antennas
BMW owners are in much the same boat, but at least their XM system comes with the ACL so aftermarket antennas are a lot easier to source.
I found a Sirius ACL (by luck) and hooked it up, then a splitter, to a new antenna. I measured the signal loss across all the cables, devices and connectors, and was surprised. So I looked up the specs for the connectors and it seems that many connections is a problem. It appears that hooking all the stuff up results in a significant degradation in signal... so the OEM solution is a pretty good one.
-s-
