E-Class (W211) 2003-2009
W211 A/C Help
Old Jun 20, 2019 | 01:11 PM
Cali Prynce's Avatar
W211 E350
W211 A/C Help
I was given a used W211 from my grandfather. The A/C is not working (blowing hot air) and I had it taken to Firestone for diagnostics. I was told that my compressor was fried. They quoted me $2500 for new compressor, condensor, drier, and expansion valve. I have all those parts brand new already. I figured i would R&R the compressor myself. I was just wondering if there was anyone with any tips or write ups so I can do this myself. I have access to WIS(?) but its on my laptop at my grandfather's house.
Any help would be appreciated. I'm mainly wondering how hard of a job it is and how to add compressor oil . I live in Texas, driving with no A/C is agonizing .
Thanks!
Old Jun 20, 2019 | 01:17 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
First of all, is the proper amount of freon in the system
Old Jun 20, 2019 | 01:25 PM
Critter's Avatar
Does the compressor turn on and off when the ac is turn on inside the cab
My E63 compressor apparently is always on, according to Mercedes
But if you need to remove the compressor make sure to have it evacuated ( complete )
Mine was basically remove the fan from behind the rad
Remove the serpentine belt
Unbolt the compressor from the block
Remove the ac freon lines from the compressor
Wiggle the compressor out and up between the fan and the engine block
Take care to not touch the rad
Replace new compressor back down the same way
Reconnect the hoses and bolt to block
reinstall all components
Take to AC shop for evac then they will refill with freon and the proper amount of oil
May need a reset from Mercedes 2 minutes to tell the compressor to start
Good Luck
Old Jun 20, 2019 | 01:27 PM
Critter's Avatar
2 hours in the driveway
Job done
Old Jun 20, 2019 | 01:30 PM
W211 E350
they told me it was OVERcharged
Old Jun 20, 2019 | 01:32 PM
W211 E350
Good Luck
It seems my compressor is always on .. When i dont have the AC on, the clutch still spins. Is this due to it being a variable clutch?? or whatever?
What about tools and jacks? Do i need any special tools?
And is the reset from Mercedes MANDATORY??
Also this was my plan :
Remove Compressor (let Freon leak into the air or whatever)
Replace Compressor and O Rings
Replace Drier
Replace Expansion valve
Maybe replace Condenser if not too difficult
Vacuum for 30mins to 1hr
Drive to A/C shop for recharge and PAG oil
Old Jun 20, 2019 | 02:28 PM
Critter's Avatar
On the AMG the compressor runs all the time
Not sure about yours
But the freon should not be overcharged
This will cause a fault and for sure the system will not run
Go to a good AC service center, have them check it out and if it is charged then there are no leaks
the compressor if have normal should I think turn on and off when actuated, let them tell you the answer
But if you are replacing the comp then have them evac the system, go home change out the comp then return to the shop and have them evac to vacuum then recharge with oil and freon to proper values, usually on the hood is a plate or sticker
The reset mine needed, but 2 minutes it was blowing cold air after the reset or fault was removed
No special tools maybe jack and some stands, remove under panel and gently remove the fan shroud etc etc
Old Jun 20, 2019 | 02:47 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
It's called a "wobble plate" or "swash plate" compressor.
R134a capacity is 0.950kg.
Oil ISO 46 capacity 120g total. Quantity less if only replacing specific parts; e.g. condenser 30 cubic cm, evaporator 40 cubic cm, etc. AC shop should have this information.
Old Jun 21, 2019 | 09:13 AM
W211 E350
Does anyone know what size the bolts are on the compressor? I know the hose connections are Allen Wrench but I want to know which wrenches to buy to take the 3 bolts off
Old Jun 21, 2019 | 01:20 PM
ATS's Avatar
ATS
2004 E500 / 2001 C240
I had the same issue about a month ago. I took it to the shop and they wanted to replace everything. I asked them to charge the system and it fixed there being no ac.
They also included some dye in the system to see if there were any leaks and there is none.
Old Jun 21, 2019 | 06:50 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Take about 2 minutes to do proper troubleshooting. If you don't have climatronic with REC button, you will need a scanner and read the notes, when to do 2 readouts.
Universal procedure at http://www.mercedesmedic.com/ac-air-...le-codes-list/
Old Jun 27, 2019 | 01:17 PM
W211 E350
Ok so i went ahead and bought ICarsofti980 so I can have so actual values to troubleshoot.
My A/C light is not stuck on . Some guy i knows did a little troubleshooting and he was able to get it to blow cool for about an hour until i started driving. If it blew cool, does that rule out the compressor??
another thing, my ambient air temperature reading is 185F . My whole wire is GONE . I already have sensor but no wire to trace back... Would this be the source of my problem??
Old Jun 27, 2019 | 03:41 PM
kajtek1's Avatar
The AC system operates on 8 or more sensors and outside sensor is part of it.
You cut 1 link in the chain and whole thing collapse.
Old Jun 27, 2019 | 07:07 PM
W211 E350
So can I buy a harness and find the wire and splice it ??
Old Jun 27, 2019 | 11:57 PM
kajtek1's Avatar
Hard to tell without seeing, but what could happen to original wire?
Good idea is to find access to the same MY car and check where the wire goes in first place.
Replacing whole harness might be humongous job.
Old Jun 28, 2019 | 07:46 AM
W211 E350
Yes the car was involved in a front end accident years ago. I found same Year and Model harness on EBay for $70 . I want to buy it and splice the wire.
Would buying the i980 scanner tell me which sensors or what is keeping my AC from blowing cold?
Old Jun 28, 2019 | 12:24 PM
kajtek1's Avatar
Maybe owner of i980 can answer? My iCarsoft MB II reads AC sensors just fine. Reading the sensors still require some interpretations and that is where forum can help. Sometimes car will display code, (that needs to b cleared before future troubleshooting) sometimes not.
Old Apr 21, 2024 | 09:57 AM
oconnorcm3's Avatar
2006 W211 E350 4MATIC Sedan
compressor reset: Can I do it with BlueDriver or by pushing dash buttons?
Does one need to go to Mercedes dealership (or equivalent) to have compressor reset, or can I do this myself?
Old Apr 21, 2024 | 03:23 PM
tjts1's Avatar
C320
What does reset mean?
