2008 E230 Crank No Start
My 2008 E230 has been down for 4 weeks now with a crank no start problem. The engine check lit is off and there are no error codes.
I initially thought it was the Intake manifold because this all started after installing a new Intake manifold.
However I tried the old intake manifold and no difference.
I then thought it was maybe spark or fuel related and checked the the rail fuel pressure which hovered around 50 PSI
I can also hear the fuel pump coming one when the key is switched on. I confirmed all the plugs have spark.
I'm now think CPS but there are no codes. Is it possible for the CPS to fail without the ECM knowing? I think unlikely.
So I'm thinking the only other things left to check is compression and timing.
Can anyone tell me if I'm missing anything?
What could this be? I'm desperate and baffled.
Lawrie
Lawrie
I was able to confirm that there was spark after removing the damaged plugs and putting in new ones. I removed each plug and grounded/earthed the body of each one and had someone crank the engine. All of the plugs produced spark. I may be wrong but information I have says that the compression of each cylinder should exceed 100 psi. I'm not sure my thumb would be able to detect this hence the reason I'm looking to borrow a compression test set. But I take your point.
Just seems odd that it all started after the intake manifold change, which would lead me to believe that it indeed had something to do with that process.
Also, how did you smash the plugs? Clearly its likely that they hit the piston tops, but that would have to be a pretty long plug thread.
Cylinder 1 =150 psi
Cylinder 2 = 145 psi
Cylinder 3 = 0 psi
Cylinder 4 = 70 psi
Cylinder 5 = 120 psi
Cylinder 6 = 90 psi
It seems like cylinder 3 is gone and 4, 6 and maybe 5 are going as well.
What do you recommend I do next?
