2004 E500 Battery Protection Issues
Both batteries have been replaced. Alternator checked out as good at the shop. After reading through the forums it seems like the next steps should be:
1. Auxiliary Battery Relay
2. Voltage Regulator
3. Alternator
4. Voodoo Witch Doctor
Does this sound about right?
The Resting Voltage is 11.7 which is lower than it is supposed to be.
So is the Auxiliary Battery Relay or Voltage Regulator the next step? Is there a way to test to see which direction to go?
Good luck,
Mike T.
1. Insert key into ignition, switch to position “1“.
2. Press buttons or repeatedly until the mileage is displayed within the Multifunction display.
3. Press cluster illumination button (1) 3 times in short succession. The battery voltage will be displayed
Good luck,
Mike T.
So that (in my mind) means the Alternator is charging). Any other tests to help narrow down the next part replacement?
Mike T.
Mike T.
Is it PART NUMBER 003 154 65 06?
https://www.google.com/search?client...+003+154+65+06
Just do not buy one that states "for a Bosch regulator", you want a genuine Bosch regulator.
Mike T.
Mike T.
First thing I would do is make sure all the battery cables are clean and tight. A loose cable will cause all sort of issues.
Good luck!
Mike T.
respectfully and valued
arjuna
Once I got to Madison the car sat for several days. I went to start it up to run an errand at it was stone dead. As in no electronics, no nothing....couldn't even jump start it.
The trunk battery was an AutoCraft Platinum AGM Battery, Group Size H8, 900 CCAand it was purchased on July 27.
I took it into Advanced to get it tested/charged and it came back with a bad cell. Still under warranty and they replaced it.
I have been traveling a lot and my car has been sitting more than it should (in Madison Winter). I drove it several times off and on in the past few weeks, and it started up in the cold without any issue. Two days ago I went to start it and it was STONE DEAD again. I am going to take it back to Advanced and get them to check it...wondering if they tell me it is another bad cell.
What are the odds this is just two bad batteries?
