E-Class (W211) 2003-2009
iCarsoft Scanners: MB II vs. MB v2.0
Old Jan 12, 2020 | 07:20 AM
Fitts07's Avatar
2011 C300 4matic
Originally Posted by mtrevelino
Kajtek1, if you are reading this, how do you check the air conditioning pressure from the icarsoft scanner? Or did you use a different scanner for this?
Its under the Air Conditioning section, go to read data stream and look through the results. Pressure should be listed. When you are in the air conditioning section the recirculation button will flash.
Old Jan 13, 2020 | 07:27 AM
ozmbguy's Avatar
W211 E500
I use a Foxwell NT624. Picks up any code a W211 can throw. Can Enable/Disable SBC & run flush.
Absolutely invaluable if you don't want to fork out for STARS to do basic tasks.
