E-Class (W211) 2003-2009
Jack point nonsense
Old Sep 24, 2019 | 06:34 PM
nsraja's Avatar
2004 E-500
Jack point nonsense
Anyone figured out the best way to support the car on jack stand? This is what I am challenged with every time. The jack picture is not an exaggeration, it is how Craftsman jacks are. I have a older one that is somewhat flat but also kind of arc so I am not sure how to jack this darn thing properly. I always put the tires under the car for extra safety which makes it difficult to get in and get out from under the car.
Old Sep 24, 2019 | 07:13 PM
Agent-A01's Avatar
05 W211 E500, 03 C215 CL55 AMG
Those jacks you have are designed to go under control arms and such.
Better to buy a proper jack stand if you need it.
Otherwise you could cut a small block out of a 2x4 to fit in the recessed square in the car's jack point to give the rounded jack stand to press against.
Old Sep 24, 2019 | 09:59 PM
Chest Rockwell's Avatar
Veteran: Navy
2005 E500 4matic wagon, 2006 AMG E55, 2009 Smart Fortwo
Jack stand pads
Try these: https://creative-steel.com/shop/mercedes-jack-pad/
I have a pair for my E55, so I don't mess up the goofy jacking point.
Old Sep 25, 2019 | 02:23 PM
nsraja's Avatar
2004 E-500
A round base still would not be suitable for most jacks, more dangerous IMO
Old Sep 25, 2019 | 04:20 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
pieces of 2x6 wood planks always work for me.
Old Sep 25, 2019 | 07:19 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
You'll also want these... https://www.asedeals.com/store/esco-jack-stand-10499/
Old Sep 25, 2019 | 11:17 PM
rodneypierce's Avatar
2009 e550 4Matic
A standard jack and jack stands work just fine.... Put the jacking point pad in the center of the jack pad and jack up the car (use the front center point) and then place your traditional jack stands under each side jacking point. Lower the vehicle. This really isnt rocket science people...
Old Sep 26, 2019 | 01:53 PM
ot1's Avatar
ot1
2006 E320 CDI
Maybe you are missing the body jack pads, they attach with only one center screw. Three were missing on my vehicle discovered after I started doing my own work. Both front sides and the front center ones. I didnt even know about the front center point until reading here just recently. Not sure if the side pads are the same as the center one.
Jack pad side part number 2039970186
