2015 GLA250 rims fit 06 W211?
2009 R320, 2006 E320CDI, 2007 SLK55 AMG
Just seeing if anyone may have experience whether rims fit from a 2015 GLA250. They are 215/5518. What I can make out online is that the bolt pattern is 5x112 and that the center bore is 66.6mm I am just unsure of the offset.
Anyone have experience?
Thank you
Thank you
Looks like the offset is +38.
https://www.wheel-size.com/size/mercedes/gla/2015/
Those tires are 17% taller than the stock 245/40/18, so your speedometer will be off by 5mph at 70. The car would have to be reprogrammed by a dealer for the new tire size in order for the speedometer and odometer to function correctly. I'm not even sure how well the taller tire would fit the wheel well. The narrower tire will also affect handling slightly.
Thanks for that info, it looks like the rims should work. I may leave the tires on for this winter and replace next year with ones that will not mess around with the speedo.
