E-Class (W211) 2003-2009
AutoTalent | Renntech Ecu + Suspension + Brakes For Mercedes-benz W211 E 320/CDI
Old Nov 23, 2019 | 12:28 PM
AutoTalent's Avatar
SPONSOR
G55
Golan@AutoTalent.com
Renntech Performance Ecu Upgrade
Click HERE to order Performance Ecu For E 320!
Click HERE to order Performance Ecu For E 320 CDI!
RennTech HHT (hand held tuner) allows you the unlimited ability to switch between tuned and stock ECU programming and requires no ECU removal. RennTech proprietary tuning module stores both the RennTech tuned file and your vehicles stock file. The module plugs directly into the OBD2 port and delivers the file you choose directly to the ECU. Programming takes only a few minutes and the vehicle can be reflashed at any time as many times as you wish. RennTech has been at the forefront of ECU tuning since electronic engine management started to show up in vehicles during the mid 1980's. RennTech experience, countless hours of in house research, development and exhaustive testing ensure that our proprietary ECU upgrade offers incredible performance gains and rock solid daily driver reliability.
Features
Long-lasting and Driver Reliability
Significant Gains in Horsepower
Increases the Performance
Significant Gains Torque
Increasing the Engine's Rev Limiter
Incredible Performance Gains
Renntech Performance Transmission Upgrade
Click HERE to order Performance 5 Speed Transmission Upgrade For E 320!
Click HERE to order Performance 5 Speed Transmission Upgrade For E 320 CDI!
Click HERE to order Performance 7 Speed Transmission Upgrade For E 320 CDI!
RennTech transmission upgrade consists of a complete transmission disassembly and inspection as well as a mechanical upgrade to the transmission clutch packs. This allows us the ability to maximize the amount of friction materials contained within the transmission and in turn, the amount of power which can be transmitted through each forward gear. During final assembly the transmission also receives all new gaskets, seals, o-rings as well as a new transmission pan filter. RennTech Mercedes Transmissions increased engine performance it becomes necessary to further improve the drive line components, most importantly the transmission in order to ensure maximum power is transmitted to the drive wheels without transmission slippage. This can not be realized with software and only truly be accomplished by an internal mechanical upgrade to the transmission hardware. RennTech is the foremost authority on transmission upgrades and has done countless rebuild and upgrades for the most demanding dealers and clients for over 21 years. RennTech upgrade leads to improved shift response, shift timing, increased torque handling capabilities and greater drivability under extreme conditions without sacrificing around town comfort.
Features
Ability to maximize the amount of friction materials
Increased torque handling capabilities
Improves vehicles responsiveness
Increased engine performance
High quality material used
Improved shift response
Improved performance
Greater drivability20
Shift timing
Renntech Suspension Toe Link Kit
Click HERE to order Renntech Suspension Toe Link Kit For E 320!
Click HERE to order Renntech Suspension Toe Link Kit For E 320 CDI!
Adding a RennTech toe link kit maintains stability at high speed, ensures the vehicle tracks straight under heavy acceleration as well as properly positions the car's suspension under heavy cornering and braking loads. When used with our adjustable camber bushings, the high-quality aircraft grade materials used in the toe links kit result in a "total package" solution that improves handling without negatively impacting ride quality and comfort. The RennTech toe link kit also allows the possibility of fine adjustments to the suspension and of bump steering for additional stability and improved vehicle handling characteristics.
Features
Ensures the vehicle tracks.
Maintains stability at high speed
Improves handling by total package method
Ipossibility of fine adjustments to the suspension2
Renntech Rear Camber Bushing Kit
Click HERE to order Renntech Camber Bushing Kit For E 320!
Click HERE to order Renntech Camber Bushing Kit For E 320 CDI!
RennTech fully adjustable rear camber bushing kit allows for a greater range of rear camber adjustment. This ensures proper suspension alignment to maximize perfomance and handling under all driving conditions and and is the companion component to our adjustable toe link kit which is required. RennTech's kits ensure proper suspension alignment to maximize perfomance and handling under all driving conditions and and is the companion component to their adjustable toe link kit which is required.When used with RennTech's toe link it, the high-quality aircraft grade materials used in the toe links kit result in a "total package" solution that improves handling without negatively impacting ride quality and comfort.
Featurrs
Proper suspension alignment
Rear camber adjustment
Maximize performance
Maximize Handeling
Renntech Performance Brake
Click HERE to order Renntech Performance Brake Package 1 For E 320!
Click HERE to order Renntech Performance Brake Package 1 For E 320 CDI!
RennTech understands that brakes are one of the most important components of any performance car. Big brake upgrades are some of the most capable systems available at any price. Designed specifically to complement and control the mass of high-performance Mercedes and AMG cars, RennTech's big brake packages deliver consistent, real-world performance and look great behind your performance wheels. RennTech basic brake upgrade uses braided steel lines (front and rear) and high-performance brake pads (front) to deliver more consistent brake pedal feel and reduce fade compared to stock. RennTech philosophy has always been to produce products without compromise.
Features
RennTech performance eight (8) piston front brake calipers
Deliver more consistent brake pedal feel
Reduce fade compared to stock
High-performance brake pads
Long-lasting reliability
How to Place Your Order:
Phone Domestic: (855) 973-2757 X 104
Phone International: (310) 231-7800 X 104
E-mail: online@autotalent.com
Website: www.AutoTalent.com
Payment:
Attachment 439933
Installations:
Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
Shipping:
All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible.
Hours of Operation:
Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only
