E-Class (W211) 2003-2009
E220 CDI 2005
Old Nov 26, 2019 | 06:14 PM
TaoShan's Avatar
e220cdi w211
E220 CDI 2005
Hi,
I have E220cdi 2005 w211 and i can't check engine oil level, i searched on the internet the ways to check oil but none of them works for me as you can see on the pictures the oil level line is missing its not there.
Any ideas how should i check my engine oil level?
Old Nov 27, 2019 | 02:38 AM
Spinning's Avatar
E90 320i, D23 Navara, EL XR8, 207 E200
tried checking it without going into that service menu?
as in turn ignition on and scroll through using steering wheel buttons until you find the oil measurement screen
Old Nov 27, 2019 | 04:13 PM
TaoShan's Avatar
e220cdi w211
Tried all 3 ways that i found on internet and none of them worked on my model its supposed to be there as in the pictures but for some reason it's not and i dont know what to do
Old Nov 28, 2019 | 02:11 AM
Spinning's Avatar
thats a little concerning, if you havent already done so i'd be changing oil and filter just to make sure it's got the recommended level of oil
although you may have already tried it, the main way i check the oil level is by turning ignition on (2 turns) and using the 2 lower lh side buttons scroll until you see digital vehicle speed, then using the up down arrows scroll until you see the engine oil level measuring message and wait a few minutes provided you've gotten the car to operating temp or you may need to wait a while longer
Old Nov 28, 2019 | 11:52 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Is it OM651 engine. ?
They took till 2014 to make it to America and forum knowledge about them is limited.
Anyway, my 2014 E250 Bluetec does not read oil level on the cluster. Wonder why after 25 years of digital readouts MB abounded the feature, but I trust MB engineers they had good reason.
Old Nov 28, 2019 | 03:38 PM
TaoShan's Avatar
e220cdi w211
I don't have that option either there is only temp, km/h and service km
Old Nov 28, 2019 | 03:40 PM
TaoShan's Avatar
e220cdi w211
Nope it is om646 with dpf and no oil dipstick and still no option to check oil trough instrument cluster.
Not even sure if sensor will say if the oil level is low
Old Nov 29, 2019 | 06:02 AM
Spinning's Avatar
does your dipstick tube just have one of those covers for it or are you missing the entire tube?
also what were the 3 ways of checking the oil that u tried?
Old Nov 29, 2019 | 12:52 PM
kajtek1's Avatar
MB start putting low oil sensor on their engine around 1986 and this is not only convenience, but also safety measure as some engines were build without oil pressure gauges.
Meaning not likely they will delete such sensor, although new technology surprised me more than once.
Old Nov 30, 2019 | 05:17 PM
TaoShan's Avatar
e220cdi w211
As i know it's for the automatic transmision dipstick tube.
1. Key on position 1 and go to temperature/kmh menu depends on what is your main screen and then press reset button 3 times and it shows me just that i posted in the pictures above everything is shown just oil level line is not there.
2. Key on position 1 and go to temperature/kmh menu and then press and hold reset button until it beeps around 30seconds and then go one menu back.
3. Key on position 2 go to temperature/kmh menu and scroll with arrows up or down until u find engine oil measurement or something like that and in this case it just shows if oil level is ok or how much to add.
and my car does not have anything of that
Old Dec 7, 2019 | 10:41 PM
ot1's Avatar
ot1
2006 E320 CDI
I do mine like this> Turn key to POS 1, select mph or temp in display, which ever has the largest font, press reset button rapidly 3 times, voltage will display, push up arrow once on steering wheel ( left side by menu) , switch key to POS 2 wait a few seconds, at rest oil amount should display, you can start the vehicle and now get running capacity.
Old Dec 8, 2019 | 11:08 AM
kajtek1's Avatar
delete
Old Dec 21, 2021 | 04:35 AM
autospeed_bg's Avatar
Mercedes
Does anyone know the oil dipstick number for this engine?
W211 2,2CDI
OM646.961
On the W203 with this engine the oil dipstick is 120 589 07 21 00 , blue color ( max-min 163-139мм)
or A 646 010 14 72
Old Dec 21, 2021 | 10:24 AM
konigstiger's Avatar
'71 Pinto
You can check compatibility here: https://www.ebay.co.uk/itm/363026093038
