Radiator Help!!
Facing my car. Leaking from where I circled.
Close up of the previous picture
Because the leak and cold heater happened near the shroud incident, to me it is likely they are related. There could be a cracked fitting that is not easy to see.
One option is a new radiator but you first need to find the actual cause (source) of leaking and no heat.
For pinpointing the leak, wipe the visible coolant and wrap the area with paper towels. That with proper timing will show what exactly leaks.
