E-Class (W211) 2003-2009
Can my 2005 Mercedes E320 CDI use Shell Rotella T6?
Old Jan 12, 2020 | 07:19 PM
Juicester's Avatar
I’ve been using Liqui Moly Long Life for past 50k miles in my 2005 Mercedes E320 CDI and I recently came across Shell Rotella T6 in the diesel section of Wal-Mart. It has the MB 228.31 certification spec on it. I’m not sure if I can use it in my car. I don’t want to start an oil war, but the price is way cheaper and it’s way more readily available.
1. What MB spec oil did Mercedes specify for my Benz back in 2005? Currently Mercedes diesels use 229.51
2. Would a MB 228.31 spec oil work in my Benz?
Old Jan 12, 2020 | 08:47 PM
mtrevelino's Avatar
2006 E320 CDI
If you are in Walmart I would go with the Mobil 1 European blend. That oil is rated for our cdi’s.
mike T.
Old Jan 12, 2020 | 09:45 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
I used T6 on older diesels and it was way superior over M1.
Blackstone charges $28 for test. Send your old oil for test, than put T6 and after 5000 miles send it for sampling.
Old Feb 23, 2021 | 09:28 PM
Bounder's Avatar
2003 E500, 52k miles
I've used Shell Rotella for many years in my Toyota Land Cruiser, highly regarded motor lubricant. That and Chevron Delo.
Old Feb 24, 2021 | 11:27 AM
alecmascot's Avatar
W204 C220CDI 2011
Looks like you should be ok.
https://bevo.mercedes-benz.com/bevolisten/223.2_en.html
Old Feb 24, 2021 | 12:19 PM
wonderwilley's Avatar
86 BMW 635CSI
I have the same car and all I use is T6. I’ve been down quite the rabbit hole with oil. I’ve been led to the opinion it’s the best oil to use on our CDIs. I think it’s basically the best oil you can get, I also ran it in my TDI and my E430. Just my two cents.
