voice control module
06 Benz e350
Hi I have 06 w211/ e350 looking on line found that my VCM looks different the part is A2214460059. tryin to figure how to test and if its connected to my tele-aide . My problem is my stereo does not work the head shows logo for few seconds then goes off. The radio stopped working after changing rear sam. I also changed AGW finall down to VCm. Please any one having this problem or Had. Help!!
Received 4,441 Likes
'71 Pinto
If you have not already done so you need to install minimum configuration (COMAND and AGW only) using MOST bridge MB part 0005454484 or aftermarket compatible then loop-in single modules until defective MOST device is located. Need VIN to supply compatible VCS module part #s.
