E-Class (W211) 2003-2009
Central locking issues 2004 E320 cdi
Old Feb 21, 2020 | 04:07 PM
Sicario's Avatar
2009 W212 E350 Avantguarde`
Hi my fellow Merc lovers, ive just picked up my 2nd Merc, im not a rich man but i know what im looking for and after looking at 6 or 7 E320`s i just purchased a 2004 3.0 V6 cdi, but its not without its minor issues:-
1) The key wont unlock or lock the car unless i hold the key right up to the door handle - Is this caused by the central locking ECU in that door? FIXED BY REPLACING THE RF ANTENNA AMPLIFIER IN THE NEAR SIDE C PILLAR
2) It locks fine, but when i try to unlock it, the plastic button at the top of the door card jumps up and down in its hole and it does not unlock - is this also caused by the C/L ECU in that door or is it the Servo mechanism? FIXED BY REPLACING THE SPRING AS SHOWN IN THE VIDEO BELOW
First jobs to do tomorrow, oil & filter change and book in for a gearbox oil & filter change, diesel injector cleaner already in the tank with £40 worth of v/power shell diesel
Also i think the steering angle sensor is duff along with 1 or more duff abs sensors as the SRS is duff and the cruise control does not engage, book in for OBD diagnostic
But initially i would appreciate your thoughts on the central locking issues.
Many thanks
Old Feb 21, 2020 | 04:43 PM
Sicario's Avatar
Ok this video is the answer for bouncing central locking, as for the key fob only working when held next to the door handle, i am lead to believe its the antenna amp behind the rear pillar trim, and something about a broken red/yellow wire? Oh my days
